Mk6 battery cable
Mk6 battery cable
Postby misty » Tue May 18, 2010 8:34 pm
Hi guys,
hopefuly you guys will know the answer, i am in the middle of a camper conversion and am at the battery stage, installing two 110 under the single passenger seat no probs, to fit the split relay i need to cut the charge cable to the battery right? and put the relay between the the lesure batts and starter batt, i only have one cable on the starter batt is that the one?? thought there might be two cables charge and supply, or am i getting it all wrong :oops: :oops:
thanks guys
misty
misty
Re: Mk6 battery cable
Postby captain hook » Tue May 18, 2010 8:45 pm
Yes.....All wrong!
Do a search on here....
You will find it well documented 8)
captain hook
Postby misty » Tue May 18, 2010 9:14 pm
captain hook wrote:Yes.....All wrong!
did you get out of the wrong side of the bed mr helpful???
misty
Postby captain hook » Tue May 18, 2010 9:25 pm
NO....Not at all..
It's just a long story to explain and....
Even harder when you type with one finger...
I could talk you through it all if you ring me!
captain hook
Postby MrMPuk » Tue May 18, 2010 9:29 pm
Plus there's no point reinventing the wheel.
Postby misty » Tue May 18, 2010 9:43 pm
please accept my apologies for asking the question, :roll: :roll: :roll:
misty
Postby MrMPuk » Tue May 18, 2010 9:45 pm
misty wrote:please accept my apologies for asking the question, :roll: :roll: :roll:
No worries, you're not the first and I'm sure you wont be the last.
Postby Nadjenka » Tue May 18, 2010 11:54 pm
Nadjenka
Postby misty » Wed May 19, 2010 7:44 pm
Nadjenka thanks a lot yep certanly does help,
better than the other two replys
once again thanks
misty
misty
