transit 2004 tdci t260 windscreen washer
Postby scribla » Mon May 24, 2010 6:56 pm
hiya guys , this is my 1st post on this forum so hope i dont ask a question thats already been asked a million times, but just brought a new van from an auction everythings fine except the window screen washer does not work, there is no sound from the motor / pump , ive checked the fuses under the dase except the relays and they all seem fine. as i dont have the handbook i do not defo know what fuse is allocated to the washers. the wipers work fine.
any chance someone has a diagram of the fuse box for this or even better a pdf or something simlar of the user hand book as im finding it hard to track one down online
just thought id ask befor i start having to check the motor / pump and change it
many thanks
scribla
Re: transit 2004 tdci t260 windscreen washer
Postby MrMPuk » Mon May 24, 2010 7:02 pm
Welcome, don't forget the search function up at the top.
viewtopic.php?f=40&t=59832
Postby scribla » Mon May 24, 2010 7:29 pm
MrMPuk wrote:Welcome, don't forget the search function up at the top.
hiya thanks for your quick reply and the revelent info, i did do a search but never seemed to show that post , any how, the fuse is ok for the washers, any steps on how to check what is wrong? im not too good with working on motors, all though i did manage to suss the oil pressure switch was not working and changed it lol
many thanks
dave
scribla
Postby angeleye » Mon May 24, 2010 7:45 pm
need to find out if there any power going to pump,use a multimeter or old way with bulb and wire,pumps do get f**ked,or clogged up
angeleye
Postby scribla » Mon May 24, 2010 7:54 pm
angeleye wrote:need to find out if there any power going to pump,use a multimeter or old way with bulb and wire,pumps do get f**ked,or clogged up
cheers many thanks
scribla
