Hi all
New here got an 02 duratec 2.4 tranny, yesterday on starting a wire burnt out, next to the fuse box under the bonnet, there is a red battery terminal (the one you use to jump start) attached onto the main power lead is a single wire that goes into the bottom of the fuse box. it was that which burnt out and broke. whats it do??
The engine still starts when warm or cold & everything still works, My first thought was that wire was to do with the glow plugs but I still get the light on the dash for them, which goes of after 5sec or so & it starts as normal from cold.
Any idea's
Thanks in advance
Trev
