egr valve 2.0tdci transit
Postby h7thl » Fri May 28, 2010 11:30 am
i have a transit swb fwd 51 reg as you look in the engine compartment from the front can some one please tell me where the egr valve is i have took the inlet manifold off and cleaned all the s---- out of it so would like to do the egr valve now a picture would be helpful
thanks in advance
h7thl
Re: egr valve 2.0tdci transit
Postby angeleye » Fri May 28, 2010 1:14 pm
cant give you a picture as i havnt a fwd but egr will sit, there is a metal pipe that goes on to a alloy casting,which goes into the plastic inlet manifold,the egr is in the alloy casting,should have a vac pipe on it,take it is a mk6 being a 51 redg so take it out and put a blanking plate in,it will stop all the crap building up in the inlet manifold,have a look in the technical how to sections on how to do it,(got pictures as well)
angeleye
Postby h7thl » Fri May 28, 2010 5:33 pm
that one is a picture of a rear wheel drive
h7thl
