Now the problem i appear to have is with my jumbo again its 125 motor that i bought a couple of year ago not long after that the engine started tapping loudly after much deliberation an conflict i chose to put a new engine in as i'm a courier i cover some miles so figured this was best.
New engine fitted 8 month down the line the turbo blew causing the same nasty tapping noise alass the engine was replaced under warranty and a new turbo fitted.
But now only 35000 mile down the road the new engine has started the same tapping noise for no reason but now out of warranty does anyone have any ideas?????
Sounds metalic obviously but like a tappet sort of thing HELP!!!!
Also have another t350 that won't start but done a mere 500000 mile so guessing an engine issue as had injection pump fitted,head recon but apparently down a little in presure cylinder one shame good van
Any advice welcome cheers thinking of taking engine manufacture to court as i rekon 35000 mile ain't really good enough from a new engine
