mk2 steering box stripped threads
Postby jerry2 » Mon May 31, 2010 9:39 pm
As title.
Refitted loose steering box after painting engine bay and noticed that someone had overtightened the bolts into the box so stripping the thread.
Any ideas of a fix without removing box?
jerry2
Re: mk2 steering box stripped threads
Postby MrMPuk » Mon May 31, 2010 9:43 pm
Could try retapping the next size up or helicoil them.
Postby jerry2 » Mon May 31, 2010 9:49 pm
What does heli coiling involve?
jerry2
Postby MrMPuk » Mon May 31, 2010 9:51 pm
jerry2 wrote:What does heli coiling involve?
Tapping oversize and putting in a wire threaded insert.
Postby jerry2 » Mon May 31, 2010 10:01 pm
Where do you get these from?
The steering box looks alloy will they still work o.k?
Think threads are currently M10.
jerry2
Postby Luke » Mon May 31, 2010 10:09 pm
i think the mk3 ones are M12 so might have been a common problem :!: :D
Postby jerry2 » Mon May 31, 2010 10:15 pm
If you can let us know where from please .
Cheers.
Do you still use the original sized bolts afterwards?
jerry2
Postby Luke » Mon May 31, 2010 10:21 pm
helicoiling you do - how many threads are damaged :?:
helicoiling is usefull where you need the origanal bolt in this case i'd just up the size to M12 doing thats easier and cheeper than helicoils :D
Postby jerry2 » Mon May 31, 2010 10:29 pm
Will let you know how I get on.
2 threads are damaged.
jerry2
