I was driving to London the other day and after about 35 miles i noticed a strong rubber smell. Pulled over and investigated and found that my passenger side front wheel was super hot, as if the brake was stuck on just a touch ,and gradually the small amount of friction had heated the whole wheel and disc etc up.
I remedied the problem by waiting for it to cool for 30 mins then tipping cold water over it, then finally spraying quarter of a can of WD40 on it.
Not the best technique i'm sure, but it got me home without the wheel heating up again at all.
The problem is now a permanent fixture on my van. Unless i spray WD40 on the disc before i go anywhere!!!
Any ideas what the problem is?
Brakes are not pulling to either side, brake pedal feels very stiff until WD40 is used, then it loosens up.
