rear tyres
rear tyres
Postby deansbro2 » Sat Jun 12, 2010 8:28 am
Hi this is my first time posting. I own a ford transit 1990 minibus that we have done a simple conversion to camper.
The van is a petrol motor and I am hunting out ways of making it less thirsty any suggestions I taked to a mechanic who said you can adjust the emitions settings but said it can be a bit risky changing the settings. We have got good power and the van in good condit we drive it slow. This might sound like a silly question but as the van has less weight than intended design is it possible to remove one set of tyres off the back axel as the van has dual tires at the back.
Thanks Hugo
deansbro2
Re: rear tyres
Postby jay » Sat Jun 12, 2010 9:21 am
no dont think you can unless you change the rear axle for the single wheel version..you will find the back axle is likely to be the low ratio one so would be better off finding a higher ratio back axle or change the engine for a diesel one.
welcome btw
mk1 connect tourneo
jay
Re: rear tyres
Postby transitandy » Sat Jun 12, 2010 11:30 am
welcome to the site m8 get some piccies up when you get a chance :)
Re: rear tyres
Postby MinorMatt » Sat Jun 12, 2010 11:37 am
I dont think there is anything illegal about taking one pair of rear wheels off, however the tyres would have to have an appropriate load rating and you would kill wheel bearings with monotinous regularity
Re: rear tyres
Postby dumper » Sat Jun 12, 2010 12:25 pm
hi you may be best to keep the twin wheel set up for a campervan as they drive off wet grass a lot better and do not get stuck as much .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: rear tyres
Postby jay » Sat Jun 12, 2010 2:46 pm
MinorMatt wrote:I dont think there is anything illegal about taking one pair of rear wheels off, however the tyres would have to have an appropriate load rating and you would kill wheel bearings with monotinous regularity
bet vosa would disagree..vehicles must have the correct amount of tyres and load rating according to the vosa plate(thats on 3501kg and above weights but dont know about vehicles below 3500kg but would say it will knock out the wheel bearings very quickly.)
mk1 connect tourneo
jay
Re: rear tyres
Postby deansbro2 » Sat Jun 12, 2010 4:53 pm
hi thanks for the advice
looks like I will have to look at other cheap options of making it less thirsty
any suggestions
thanks hugo
deansbro2
Re: rear tyres
Postby captain hook » Sat Jun 12, 2010 5:59 pm
deansbro2 wrote:hi thanks for the advice
any suggestions
thanks hugo
Sell it and get a Tent :lol:
captain hook
