ake wrote:The fuse is also to protect you, remember you are sitting on top of the batteries, if you were involved in a accident and the starter cable shorted the batteries could explode if the fuselink wasn't there,at the end of the day bodge it if you want but dont come running to me with acid burns on your arse
I'll second that
especially as theese vans are prone to starters failing, if one goes short circuit or jams up the enormouse current drawn from the battery, will, at best set fire to the cables
and at worst cause the battery acid to litterally boil until they explode and go open circuit.
This fuse has one of the most important jobs out of any of the electrical sytems fuses, and SHOULD NOT BE BYPASSED under any circumstances.
Had many a case on older cars when the starter bendix jammed in, but motor couldnt crank engine.......rushing to remove scalding hot battery leads as fast as spanners wuld allow before someones beloved vheical became an inferno
Do what you like, we can only advise, but do so at your own peril
on a more constructive note WHY would you want to replace with something else, has your blown
