Hi
I bought a transit 2001 mk6 and noticed a leak which I thought was gearbox oil but on closer inspection turned out to be cooling fluid. Pipes had rotten so got them changed but the garage now tells me it needs a new solenoid on the fuel pump (£400 plus vat) which on inspection I can see diesel leaking from. Also sometimes when i put the van into 1st as i pull away it can jump out but only when pulling away no other time, it can also be a little tricky to go into 4th and the same with reverse as with 1st, any ideas? Also i noticed diesel around the plugs but I have cleaned this off and it does not seem to have reappeared but will check after driving tomorrow, Does this van sound like its going to cost a fortune to put straight? As far as I can tell the van runs lovley and is very clean and straight with 139000 miles on the clock and only those things above.
