Generator/compressor sets
Postby Eugene Speed » Thu Jun 17, 2010 10:29 pm
Can anyone enlighten me as to how the Transits operated by many of the utility companies run onboard compressors and generators? Are they powered by the vehicle engines or do they have a seperate motor? And where would I get hold of such a set? I could really do with onboard power and air but would prefer it to be an integral part of the vehicle so it's one less item to be carried around in the loadspace.
91 Transit County 4x4
88 Transit 130 armoured van
99 Transit spec lift
90 Fiat Panda 4x4
http://facebook.com/eugene.speed
http://tuffcomputercompany.com
http://transitcounty4x4.co.uk
http://truthsearchersuk.org
Member of the Mk3 Massive! :)
Eugene Speed
Re: Generator/compressor sets
Postby MrMPuk » Thu Jun 17, 2010 10:31 pm
They are driven by a PTO on the gearbox.
Postby Eugene Speed » Thu Jun 17, 2010 11:02 pm
Would that be a modified MT75 box? :shock:
Don't suppose anyone has any pics or diagrams of how the setup works and fits under the van? :?:
I'd be very interested in learning more, I could probably get a PTO from my County's transfer box without too much trouble. :idea:
90 Fiat Panda 4x4
Eugene Speed
Postby MrMPuk » Thu Jun 17, 2010 11:04 pm
The PTO fits between the gearbox output shaft and the propshaft. Probably quite a difficult thing to do on a 4x4.
Postby Eugene Speed » Thu Jun 17, 2010 11:19 pm
Probably not too hard to do, as the transfer box can be shifted to neutral while the engine spins the short prop from the gearbox to the transfer box. A PTO unit or pulley could be fitted between the prop and transfer box. I'd like to get a look at a PTO unit to see if it might be useable in this way.
90 Fiat Panda 4x4
Eugene Speed
