Which type injector is this?
Postby mvdlans » Tue Jun 29, 2010 5:54 pm
Bonjour,
I have a 2.5 diesel from 2000 and it has some leaking injector end caps. The end caps are screwed on the fittings for the return pipes. I went to the local Ford dealer but they told me my injectors weren't original so they couldn't help me. I've glued the endcaps in place but this isn't a long time sollution. Due to the normal vibrations eventually the whole stuff unscrews....
You screw the end caps on to the injectors. But the former owner messed up the fine screwthread inside the cups. Since my ford dealer and other diesel specialists couldn't help me I'm trying to find the manufactorer of my injectors. I couldn't find any numbers on them though.
They look simular at thes I found at United Diesel UK
http://www.uniteddiesel.co.uk/diesel_injectors/ford/
Thanks in advance
mvdlans
Re: Which type injector is this?
Postby MrMPuk » Tue Jun 29, 2010 5:58 pm
That is the ones, exact ones will depend on the engine you have though.
Postby mvdlans » Tue Jun 29, 2010 8:28 pm
Ah, ok,nice.
But what do you mean with 'it will depend on the engine?'
It is just the plain old 2.5 without turbo.
mvdlans
Postby MrMPuk » Tue Jun 29, 2010 8:42 pm
70ps or 76ps.
Postby mvdlans » Wed Jun 30, 2010 9:02 am
Aha, merci.
How can I see the difference? I checked the carpapers but there's noting in there regarding to the max torgue. Can I find this info in the VIN number maybe?
Thx,
Michiel
mvdlans
Postby Altransit » Wed Jun 30, 2010 9:16 am
The 76ps engine will have the "bunch of bananas" inlet manifold, and the 70ps "doesn't" ................ assuming yours is a non-turbo engine :D
Postby jay » Wed Jun 30, 2010 7:03 pm
take a pic of your engine bay and post it up..
mk1 connect tourneo
jay
Postby turtleautos » Wed Jun 30, 2010 8:14 pm
surely the injectors are the colour coded ones, paint spot orange, red egc for the differant power settings, i am going back abit now lol
turtleautos
Postby jay » Wed Jun 30, 2010 10:15 pm
turtleautos wrote:surely the injectors are the colour coded ones, paint spot orange, red egc for the differant power settings, i am going back abit now lol
yes but by now most of the paint will either be under the glue or the paint has come away due to the rust on the injectors...76ps will be banana engine(orange spot i believe)70ps is black pipe from air box to inlet manifold or may have square air filter ontop of engine(think green spot)
mk1 connect tourneo
jay
Postby turtleautos » Wed Jun 30, 2010 10:21 pm
good point paint used to be on the flat on the part where the pipe screws on lol
turtleautos
Postby AndyG » Thu Jul 01, 2010 12:04 am
From what I can see, it's a banana with red spot injectors, but the numbers are important because there were production changes to the fuel system :!:
I can't see how Ford's or so called specialist diesel shop can't help you, as it looks standard enough to me :!: (unless they were referring to the glue :?: :lol: )
You must fit the correct injectors to avoid either heavy smoke or lack of power :D
Postby mvdlans » Thu Jul 01, 2010 9:37 pm
Yep, it's a banana with red paint injectors. So it's the 76 ps version.
E-mailed united diesel and they can help me out with endcaps.
And about my diesel specialists, well, frenchies stay frenchies eah? :wink:
Unless, you want to park the car over at them and let them repair it for you....
Greetz,
Michiel
(A Dutchy, qurious for tomorrow's match: holland-brazil)
mvdlans
