transit 51 - SWB - can't get it into gear
Postby ryan2010 » Tue Jul 20, 2010 9:50 pm
Hi All,
I can't get it into gear. It was working fine today, but, when i put it into reverse which I had to force. I managed to park up but, had a look at it later and now the clutch pedal is half way down to the floor - turned the engine over depressed clutch but won't go into gear at all. It has been a bit suspect putting it into first over the last couple of days.. I thought it may have been the gear linkage, any suggestions to what it is?
Thanks,
Ryan
ryan2010
Re: transit 51 - SWB - can't get it into gear
Postby h7thl » Wed Jul 21, 2010 12:42 pm
my 51 plate swb transit done the same i went under it sprayed wd40 on the transfer box and linkage on top of the gearbox and it works fine ever since
h7thl
Postby Mikey B » Wed Jul 21, 2010 3:32 pm
Clutch pedal sticking half way down normally means the master cylinder is knackard..
MKB Autos All makes and models catered for.
Mikey B
Ford Technician
Postby jay » Wed Jul 21, 2010 5:59 pm
if it will go into gear with the engine not running then all is ok gear selection wise....if by how you mean the clutch pedal has no feel and goes straight to the floor you got a leak somewhere most likely to be slave cylinder in the gearbox..but first check the fluid leval..
and h7th if you only sprayed wd40 then the linkage will seize up again soon as wd40 is not a lubricante so you may want to oil up the linkage whice will stop it seizeing in the future..
mk1 connect tourneo
jay
Postby ryan2010 » Wed Jul 21, 2010 8:21 pm
Thanks for your replies.
There is no trace of oil near the clutch pedal so does that suggest the master cylinder is OK?
The actual position of the pedal is down, I can move the pedal freely with my hand but does return back to the floor once let go.
With the engine cut it does freely go into any gear hence the only way to move is to turn the engine on while in gear. I have phoned around a few garages and they also say that it is likely to be the slave cylinder. I have had quotes of £340 up to over £600 to rectify (including new clutch) under the assumption that this is the problem. I have seen prices of the part (slave cylinder) from £40 to £180 does anyone know the real price for this part?
Thanks,
Ryan
ryan2010
