I'm in the process of buying a MK6 Transit for the first time, and the 1 I've seen sometimes when changing from 1st to second doesn't engage properly until you shift it the second time, it's a 100ps model 2001, is this a major problem, or a replacement cable job, mileage isn't high. Also here's a small rust hole under the passenger door on the footplate, is this a big problem or normal?
Cheers
Ken
