I have a problem with my van, hence the post.
Easier to add picture off problem as well as explaining, as you will all see.
Instead of an adjusting bolt in the empty hole, there was a household bolt with 2 x nuts. It had jumped off Monday (Only found out as was making a huge banging noise from rocker cover so thought oil was not getting through & took it off) re-fitted it, or re-bodged it as many would say, but jumped off again today after about 2-3 hours use, but as can be seen in the picture the push rod is much lower, anyone any ideas? Help! Have I killed my engine?
I have no clue what to do now, thanks in advance.
Ron
