by Tinbasher » Fri Sep 10, 2010 12:21 am
Hello there. I've just joined this forum, so thanks a lot.
I have an issue with electric speedo too. I changed the gearbox 2 weeks ago. I had originally an electric speedo that worked fine. My gearbox lost both reverse and 5th gear (I'll ask about that later). I had the elctronic sensor (on the nearside rear of the box) and where a speedo cable would be was a blanking plug.
I got another gearbox from a scrapyard (60 quid) and noticed it has both the cable drive outlet (on the O/S) AND the electronic unit on the N/S. same as my old one. The lads had cracked the male end of the multi-plug that connects the unit to the wiring loom. No worries, I got the box back to work, and swapped the units as a first thing, only because my plug connector was better mainly. It was also a known working unit. I had to tilt both boxes on their sides when swapping the units, else all the oil comes out.
I've fitted the box and all the gears are fine, smooth, no noises. But no speedo working. i'm positive I've connected everything correctly. The problem now is that if I wish to swap back or replace with another (scrapyard?), I will lose the oil when I remove it. I'm not too bothered about that cos it is probably wise to replace it anyway and that has been my intention, but I don't want to do that and still not have a speedo working and then have to do it again.
I admit, I didn't know it was fused and haven't checked that, but if fuse is ok, what next?
The only differnce from my old set-up is that I now have an un-used cable drive peeping out of the box, whereas it used to be blanked off, but otherwise the electric sensor is fitted and connected exactly the same.
