noise from front hub mk5
Postby pat stevens » Fri Sep 10, 2010 3:16 am
ive got mk5 s reg (admitedly i got wide wheels on it i know the bearings need sorting reg) ive had new bearings discs ball joints track rod ends shockers recently . im getting a sound simlar to a wheel bearing hum ive checked bearings and are ok any ideas anyone
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Re: noise from front hub mk5
Postby rover » Fri Sep 10, 2010 9:00 am
Its probably the propshaft bearing you can hear.
rover
Postby pat stevens » Fri Sep 10, 2010 9:31 am
no m8 defenatly from drivers side front
pat stevens
Postby Luke » Fri Sep 10, 2010 9:34 am
try taking the wheel bearing up :idea: tighten all the way up then back it off untill it spins free - see if it alters the noise :D but if it is that it'll probly need new bearings in :|
anyway wheres the pics of this van :?: :mrgreen:
Postby pat stevens » Fri Sep 10, 2010 9:40 am
its had new bearings 2 weeks ago and again yesterday on drivers side after changing the hub as new bearing desintegrated on m1 spent 6 hours on watford gap services wednesday (at least the sun was shining lol) waiting for m8 to bring spare hub big credit to central moter factors from northampton they deliverd new bearings to us with no delivery charge. mrs tried to put van pics on but failed miserably (you may just see it on ebay if things dont get sorted with it as im getting really fed up with it )
pat stevens
Postby Luke » Fri Sep 10, 2010 9:47 am
when you jack it up is there any play in the wheel :?: sometimes when fitting the bearings they dont seat right and as they get used they seat correctly but then the gap is too much :idea:
does the noise alter when you go on/off the accelerator :?: :idea:
Postby pat stevens » Fri Sep 10, 2010 10:05 am
no play in bearings noise still their even when coasting im gonna try some new brake pads in case the other ones are just touching the disc but they look ok . never had so much trouble with somthin so stupid. the last 3 days spent out nearly 400 quid and still not rite i want another mk 2 at least itll be a real transit
pat stevens
