fortyeight wrote:hi my warning light stays on a while been told its delayed action from split charger
solarman wrote:Sorry to but in but was wondering what is causing a low charging reading on my van's alternator?The other day i measured my battery and it was showing12.1 volt not running,today i decided to measure the voltage on battery while engine was running and i was gettingb a reading of 12.3,12.4 slowly rising,but i was expecting a reading of 14 .4 ish as an alternator
would be charging at about that voltage,it has been starting okay but i will need to sort it out as it is undercharging as far as i'm concerned,
Solarman.
Forgot to mention thbat i don't hbave an alternator light lit on dashboard which is unusual if it's not chbarging properly.
solarman wrote:It's a multimeter and yes only checked it while engine is running,will do another check after a long drive see if it makes a difference,thanks,
Solarman
ake wrote:solarman wrote:It's a multimeter and yes only checked it while engine is running,will do another check after a long drive see if it makes a difference,thanks,
Solarman
Do you have acces to another vehicle that you could check your multimeter on and then you would have readings to compare with
