by pete_g111 » Sun Oct 03, 2010 12:51 am
Ok, so I have a 1996 turbo diesel MK5 transit with lucas epic fuel pump. & like many, it has been having some issues starting. would just get a click from the shut off solenoid when I tried to start it. occasionally it would fire.
Traced the problem to the shut off solenoid, replaced the valve and there you go, it started and stopped beautifully. however the enging management light stayed on for 3 or 4 seconds after it started which i have heard means that a fault has been logged???
But now after a few days its been getting worse and worse to the point now where it wont start at all.
I'm almost certain its an ecu fault which is stopping the engine from starting.
Can I do something to reset the ecu, something with immobiliser, i dont know? Ive heard loads of things like disconnecting the battery etc. don't know how true or reliable these things are?
Thanks!!!
