Ex RAC Transit Anderson Plugs
Postby daddyvan » Sun Oct 03, 2010 9:36 pm
Hi All,
Newcomer here wondering if anyone can help. I have a 2001 ex RAC Orange Transit, it is a 330 (RWD). It still has what I now know to be called Anderson plugs below the front grille, below the rear bumper and also just inside the side loading door. Does anybody know which size I need to hook up to these? I know they bear markings but cannot find a definate match after looking on line.I know they are genderless connectors but find they come in many sizes. I have bought a set of TVR jump leads off of E Bay but find they have a smaller Anderson type connector than the van. Also I cannot see how they come apart. I assume the cables are a push fit and seem to be spring loaded inside casing but can they be removed without damaging the casing? Any Help with this would be much appreciated.
Cheers
daddyvan
Re: Ex RAC Transit Anderson Plugs
Postby MinorMatt » Sun Oct 03, 2010 11:16 pm
Not sure how useful this will be but "barden batteries" sell anderson plugs and may be able to advise?
Postby MrMPuk » Mon Oct 04, 2010 12:24 am
I believe they are colour coded. Yes you can get the cables out, I use a screwdrive to release the catch.
Postby MrMPuk » Mon Oct 04, 2010 12:35 am
Was wrong, colour is the voltage which you will obviously need to know, amps should be on the back which is the size.
Postby daddyvan » Mon Oct 04, 2010 12:17 pm
Hi again.
Thank you gentlemen for your replies. I thought a screwdriver should be able to release the cables but where is the catch you speak of? Do I get to it from the front or the back of the casing. If I can unclip them I can Swap housings and get my leads working! Thank you both again for your help.
Cheers.
daddyvan
Postby MrMPuk » Mon Oct 04, 2010 2:48 pm
You wont be able to just swap the housings as the connections inside will be different.
Postby Honey monster » Mon Oct 04, 2010 3:21 pm
Pop to your local breakdown guarage,They prob use the same connections and can advise you where to get them.
Honey monster
Postby bigdog-dingo » Mon Oct 04, 2010 6:42 pm
For Anderson plugs & bits try your local HGV parts suppliers & motor factors . PLUS ask nicely at any fork lift truck places you might see , they all use& stock various sizes
hope it helps :)
bigdog-dingo
Postby SirKit Breaker » Mon Oct 04, 2010 9:25 pm
daddyvan wrote:Hi again.
Cheers.
Grab hold of the cable and push it forward, looking into the pin end of the plug you will see that the pin has a lip on its underside, into that you will see a thin metal plate, this is the spring holding the pin in place. push the plate down with the edge of a screwdriver and the pin will fall back and drop out.
Cheers........Howard
GREAT BRITAIN LOVE IT OR LEAVE IT.
SirKit Breaker
Postby daddyvan » Sat Oct 09, 2010 12:09 pm
Hi All
Thank you once again for all the help, particularly SirKit. Once I knew what I was about I removed the cables from the housings no problem and with a little bit of fettling got the housings swapped. Just had to file the ends of the cables a bit and they are now a good tight fit. Now for the next job...
daddyvan
