What symptoms should I get if 1 or more injectors are failing?
the symptoms I have are :
rough idling (I have turned the idle screw up a bit)
slight missfire with some Black smoke if I open the throttle fully at a stand still
plenty of torque till about 3000 revs with a bit of a dead spot but seems to regain torque after 3100 revs (Revs are approx as I have no rev counter)
Gutless after motorway journey but after it has cooled it returns to the same as it was before with the above symptoms.
items Replaced are :
Fuel filter 1st August 2010 ( Fuel Has not run too low since, the light has come on but I only drove to the garage which was 0.5 of a mile away)
I have cleaned the torque sleeve and piston at the same time.
I did the leak off mod 30th September 2010 (got more torque now)
Fuel pump replaced 4th October 2010 (there was no change after this)
I do have a leak of exhaust Gasses from where the EGR pipe meets the Manifold as one of the bolts were snapped when I removed the pipe to replace the rocker cover gasket I shall be getting a second hand manifold from the breakers soon making sure none of the bolts are snapped this time.
the engine is still the standard 70HP non turbo DI with no other things added or removed.
