lowering a mk6
lowering a mk6
Postby dixiebmw » Thu Oct 07, 2010 10:32 pm
does anyone know if you can lower the transit by making lowering blocks and clamping them between the leaf spring and axle like the old escorts and cortina mk2 s
dixiebmw
Re: lowering a mk6
Postby MrMPuk » Thu Oct 07, 2010 10:33 pm
Blocks between the axle and spring will make the van higher.
Re: lowering a mk6
Postby dixiebmw » Thu Oct 07, 2010 10:45 pm
is there a cheap and easy way to do it
dixiebmw
Re: lowering a mk6
Postby MrMPuk » Thu Oct 07, 2010 10:45 pm
Have a search on here and look at the other posts on the subject, will either inspire you or put you off.
