51 reg t 280 75 transit timing solenoid
Postby napster » Sat Oct 09, 2010 7:43 pm
I'm having trouble with my transit at the mo it turns over quickly but doesn't fire. It runs after towing it but doesn't start after a while. I'm wondering if it could be down to the timing solenoid not the metering solenoid that's in-between the injector pipes .
Thanks tony
Hopes and dreams
napster
Re: 51 reg t 280 75 transit timing solenoid
Postby Frag » Sat Oct 09, 2010 8:57 pm
Not likely to be either of those 2 i`m afraid...............
Either air ingress/filter head fuel supply...............
OR pump failing.
More details, :idea: i.e vehicle may help
Frag
Ford Technician
Postby Frag » Sat Oct 09, 2010 9:05 pm
My bad,didn`t read thread title :oops:
Diagnosis still stands tho i`m afraid. :(
Frag
Ford Technician
Postby napster » Sat Oct 09, 2010 9:11 pm
Changed fuel filter. There is diesel to the injectors cracked each one off individually and cranked fuel to theses points
Hopes and dreams
napster
Postby napster » Sat Oct 09, 2010 9:17 pm
Were would I start looking for air ingress. Eg which hoses .
Thanks Tony :)
Hopes and dreams
napster
Postby jay » Sat Oct 09, 2010 10:13 pm
u would have been better off just keeping 1 thread on the subject and just adding to the thread u started..and stop towing it as was advised in the other thread
mk1 connect tourneo
jay
Postby napster » Sun Oct 10, 2010 10:32 am
Probably mate. I've not towed it since advised not to don't want to knaker it ant more than it is
Hopes and dreams
napster
