MrMPuk wrote:Not a valid code for your engine. What are you using to read the codes?
Grenadekid wrote:Found this Altransit its similar but not the same, maybe you,ve already seen it![]()
http://fordtransit.org/forum/viewtopic. ... 48#p499646
Altransit wrote:Grenadekid wrote:Found this Altransit its similar but not the same, maybe you,ve already seen it![]()
viewtopic.php?f=5&t=57996&p=499646&hilit=p0148#p499646
Yes, I've seen that post, but discounted the timing solenoid as the pump was replaced.
There was another post with the same two codes as mine, but the poster never returned with a conclusion
Altransit wrote:http://fordtransit.org/forum/viewtopic.php?f=2&t=8845&start=0
Altransit wrote:Pump and injectors were replaced to cure the black smoke, but ............................
Users browsing this forum: Alifbaa02
