heaters
heaters
Postby tony1991 » Wed Nov 10, 2010 7:54 pm
hi guys
i have a 51 plate swb since i had it the heaters have not worked well not got hot or even warm now comin to cold weathers its horrible any one have any ideas
thanks tony
tony1991
Re: heaters
Postby AndyG » Wed Nov 10, 2010 10:07 pm
If the temp gauge is reading low, change the thermostat :idea: But make sure you get the right one :!:
Go directly to Ford's, as after market ones might not be for your exact application :!:
Re: heaters
Postby angeleye » Wed Nov 10, 2010 11:02 pm
x2 with the ford thermostat also give the system a good flush out,reverse flush the rad,and use the correct red antifreeze
angeleye
Re: heaters
Postby fortyeight » Thu Nov 11, 2010 7:20 pm
is the tempriture gauge working as it should
fortyeight
