Steering wheel play,can i...................
Postby Dave190 » Sat Nov 13, 2010 3:00 pm
Ok,heres my first question/problem,probably a daft one!!
I've got about an inch of play (in/out) in the steering wheel,iv checked the UJ coupling/joint,seems fine.
I 'think' it needs the steering column thrust bearing replacing.Iv not had much luck in sourcing where to get one though!
Couple of people have told me to just replace whole column(others the whole van :roll: ),surely if it is the bearing then i could just replace that??
its a 1999 mk5 2.5d.
i posted in this section rather than mk5 as thought it may apply to others too??
Any help be great.
Build Date: 17.02.1999 --Vehicle Line: Transit 95 --Cab Style: Regular Cargo Van --Series: 190L
Engine: Diesel 2.5 (76PS) --Transmission: 5-Speed Manual - MT75 --Drive: RHD RWD --Axle Ratio: 5.14
Paint: Diamond White 73
Dave190
Re: Steering wheel play,can i...................
Postby rover » Sat Nov 13, 2010 8:17 pm
The column bearing wont stop in and out play, the only way you can get that sort of play is if either the uj or the rack is knackered :!:
rover
Postby dumper » Sat Nov 13, 2010 11:51 pm
or the ball joints
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby captain hook » Sun Nov 14, 2010 2:25 am
rover wrote:The column bearing wont stop in and out play, the only way you can get that sort of play is if either the uj or the rack is knackered :!:
dumper wrote:or the ball joints
If you read the post it says "in and out" NOT left and Right. :roll: :roll: :roll:
The problem will be in the column... :D :D :D
captain hook
Postby MrMPuk » Sun Nov 14, 2010 5:37 am
Correct me if we're wrong but aren't the column bushes there to stop left and right play not in and out?
Postby rover » Sun Nov 14, 2010 11:48 am
Colum bushes are to stop the steering cloum inner rattling around in the outer, nothing more nothing less! It is of course an MOT failure if they are loose/worn, but most testers dont even test for it any more as its so uncommon.
You wont stop in and out play by replacing the bushes :!:
Its not a common fault on Transits of any age, but I have done litteraly hundreds on other older vehicles like Mini's, Reliants, Opels etc.
rover
Postby AndyG » Sun Nov 14, 2010 12:31 pm
Probably needs the steering wheel nut tightening :?:
Postby darkbluevanman » Sun Nov 14, 2010 8:18 pm
didn't some colubms have a inner piece that collapsed (or slid down) in the even to of an accident??
darkbluevanman
Postby AndyG » Sun Nov 14, 2010 8:38 pm
If there is a fault with the column, I can't see it being a major job to swap out anyway :!:
There's no difference between all the smiley Transits and so should easily be able to pick one up from somebody that's breaking one :idea:
Replace the whole van
:roll: :lol:
Vans got dirty, time for a new one :!: :P
Postby Dave190 » Mon Nov 15, 2010 4:05 pm
Thanks for all the replies.....................
Nope,its tight.
Theres no play in UJ for sure,and rack is ok (i think/hope) as the play (in/out)is definatly top side UJ.
Im going to collect a used column from a local breakers some time this week,fingers crossed that will sort it!!
Dave190
