MinorMatt wrote:Incidently guys - this is on a mk3 if it makes any difference!
madmark wrote:this sounds like a vv carb
madmark wrote:you can adjust the choke on them ,have you got a manual?????
madmark wrote::lol: on your old bus you will find that its had a manual choke conversion ,people left the part in that you are on about rather than fitting the pipe joiner![]()
what happens with vv carbs is they overchoke once they are off choke they are normaly a good carb!
you could get a conversion kit to convert it to manual or replace the carb or try and adjust it , have a mess about with it and undo the 3 little screws and see what going on with the spring,once thing i will say if the choke wont work it wont start
madmark wrote:yes mate it will fit ,these were the best carbs on the transit pinto,s imo ,but you need throtle linkage and gasket etc
