front fog's wont work...
Postby mercedes190d » Fri Nov 26, 2010 8:36 am
hi my fog lights have not worked since i had my van its 05 tourneo, i have replaced bulbs, headlight switch all new, and still not working, all fuses are fine any ideas?????? as not an electrician know basics, as there is no power at the fogs when tested with a meter?? any help appreciated on how to get power there.. thanks..
mercedes190d
Re: front fog's wont work...
Postby Altransit » Fri Nov 26, 2010 11:26 am
There is probably a relay that's not working, try the fuse box :idea:
Postby AlanN » Fri Nov 26, 2010 4:00 pm
Altransit wrote:There is probably a relay that's not working, try the fuse box :idea:
agreed
Postby ake » Sat Nov 27, 2010 12:01 pm
I dont think there is a relay for the front fogs on a MK6, sure its just the switch :?
Postby mealic » Sat Nov 27, 2010 2:38 pm
I presume that you have checked to see if they are plugged in to the factory connectors on the "chassis rails" at the front.Two sockets are just clipped up normally.
Does your van have the two position fog (pull,pull)switch as my Mk6 originally only had the one pull that operated the rear fogs.If the fronts were after market wired they should really be fitted with a relay.Probably under the passenger side tray.
`04 2.3 petrol/LPG
mealic
Postby AlanN » Sat Nov 27, 2010 9:10 pm
Can't see a manufacturer running a cable of that ampage to fog/spots via a dash switch, it must have a relay...
Postby mercedes190d » Mon Nov 29, 2010 9:00 am
hi thanks for reply yes it has the front fog switch as purchased a new one as the one in there was just the one pull out switch, have checked all fuses, and wires are all connected on chassis rails, if its a relay any idea which one it will be thanks.
mercedes190d
Postby Timbo » Mon Nov 29, 2010 12:09 pm
If the van didn't originally have the front fog switch then the wires may not be in the connector for the light switch. There should be an Orange/Yellow wire from switch to front fogs - make sure it is in the connector and loom. Check if the front fog indicator on the dash works.
Timbo
Postby mercedes190d » Mon Nov 29, 2010 12:37 pm
hi front fogs factory standard on this model, front fog light lights up when turned on but still nothing everything is connected any one know if there is a relay and which one? thanks
mercedes190d
Postby mercedes190d » Wed Dec 01, 2010 5:10 pm
right i have now found that somone have re wired the fogs and there is a relay where the wires meet with spades on them the diagram on the relay say 30, 85, 86, 87
i aint a clue what they mean but there is ony a small 1.5 v going to the one spade any one tell me how to do this tidy so they will work tidy thanks
from scratch as will run new wires, relay, connectors. just need to know where the wires will go on the relay from the fogs power in power out etc. :?
mercedes190d
Postby ake » Mon Dec 06, 2010 12:22 am
30= Live feed from battery via fuse
87= Switched output to Lamps
85= Earth
86= Switched input from switch
