NO INTERIOR CAB HEAT FROM TRANSIT
Postby cream2cream » Tue Nov 30, 2010 4:33 am
hello, seems my transit dont wanna blow hot air when fans switched on, just blows out freezin cold air, put a cardboard in front of rad dont make much difference
doesnt overheat whilst stuck in traffic so i know there's not a air block
anyone experience this problem? :roll:
thanks
p.s. its cold :cry:
cream2cream
Re: NO INTERIOR CAB HEAT FROM TRANSIT
Postby rover » Tue Nov 30, 2010 9:36 am
Heater matrix is blocked, you can try to flush it by taking one of the pipes off and sticking a hose up it, you will need fresh anti-freeze after of course :wink:
If that doesnt help then you need a new matrix.
rover
Postby Timbo » Tue Nov 30, 2010 12:29 pm
If the two water pipes to the heater are getting hot then it could be the temperature flap in the heater box not moving with the heat control on the dash.
Non-aircon use a cable to control the flap. If the control doesn't seem to be doing anything it may have come disconnected and the flap is stuck on cold setting.
Timbo
Postby MattBlackMinibus » Tue Nov 30, 2010 12:36 pm
Bought a Rascal once with same problem.
Turned out it had no water in the engine.
Starting All Over Again
MattBlackMinibus
Postby dirtydog » Tue Nov 30, 2010 7:09 pm
Ive got a similar problem with my mk5.
when I turn the blowers onto 3 (needs a new heater resistor) it blows hot air for about a minute then goes luke warm. If i turn the blowers to 2 (knackered resistor remember :wink: ) hot air comes out when i drive along but not at slower speeds or stopped
checked the water level at the weekend and it was fine
any ideas?
dirtydog
Postby cream2cream » Tue Nov 30, 2010 7:15 pm
hello, mechanic says someone has problems taken the thermostate out, :roll: as all the pipes r hot, the matrix aint blocked
:D
anyone know how much a new one is?
thanks
cream2cream
Postby redcube » Tue Nov 30, 2010 7:24 pm
i have no hot air when stop but pick up speed i get hot air
redcube
Postby APH » Tue Nov 30, 2010 7:31 pm
cream2cream wrote:hello, mechanic says someone has problems taken the thermostate out, :roll: as all the pipes r hot, the matrix aint blocked
:D
thanks
if you use a motor factors, then between £5 and £15 depending where you go. If you go to fords, about £38 :shock:
(\__/)
(")_(")
this is bunny
APH
Postby crayon » Tue Nov 30, 2010 8:10 pm
Changed my thermostate the other day as mine was blowing out cold air its great now, what is the temp gauge showing on the dash?
crayon
Postby cream2cream » Tue Nov 30, 2010 9:48 pm
i will do the same 2morrow
cream2cream
Postby cream2cream » Sat Dec 04, 2010 12:21 am
changed it and dont make a difference, although i have noticed that the fan just spins around even when u start it up from cold
cream2cream
Postby crayon » Sat Dec 04, 2010 9:04 am
Could be that the bearing in the fan has seized, can you turn the fan with your hand when the engine is off?
crayon
Postby cream2cream » Sat Dec 04, 2010 12:20 pm
yes spins fine
cream2cream
Postby cream2cream » Sat Dec 04, 2010 12:21 pm
shorted the temp guage and it works fine
cream2cream
Postby rover » Sat Dec 04, 2010 6:01 pm
Try going back to the top of the thread :!:
rover
