My 2.5 Diesel Transit, poss diesel problems. Please Help
Postby fordgeek » Sat Dec 11, 2010 4:17 pm
Hello all,
I have a 1998 Ford Transit 2.5 Diesel. It does'nt start, it turns over but just does'nt seem to catch. i got it running earlier today, with a bit of easy start and it was running but running very rough and nothing happened when accelerating. I had it running for about 10 minutes then cut out and would start again! (possible injector pump or injector problems) I have changed the lift pump and it does'nt seem to be that. i have opened all the 4 injectors and all 4 have diesel coming out of them. My thoughts are for some reason there is not enough diesel getting around the engine. There is over a quarter of a tank of diesel in it. It sounds like it wants to start but something stopping it from doing so. Any of you guys had a similar experience, all your opinions will be much appreciated.
fordgeek
Re: My 2.5 Diesel Transit, poss diesel problems. Please Help
Postby Steve B » Sat Dec 11, 2010 6:58 pm
A change of fuel filter might help, fill the new one to the brim, refit it, get somebody to turn the engine over whilst you slack off each injector one at a time and when fuel starts showing retighten, should fire up unless there is another problem
Steve B
Postby ake » Sat Dec 11, 2010 7:00 pm
When did it last get a timing belt? May be stretched putting timing out
Postby rustysmileysdad » Tue Dec 14, 2010 6:14 pm
on the back of the injector pump where the return pipe goes back to the fuel filter housing ull notice the bolt holding the pipe in is a long one it has inside it a spring and ball bearing and i think a gause fillter make sure it is all clean inside and bleed from there i had this prob and it sorted it but on the same note on another ocation it was fillter head
rustysmileysdad
Postby psv-hgv-flt » Tue Dec 14, 2010 8:10 pm
allso check fuel feed pipes at the back of the head above gearbox bell housing (on the bracket that no one puts back when g/box comes off) :lol: :lol: may be choped...??? due to vibration.
psv-hgv-flt
