TRANSIT TIMMIMNG CHAIN
Postby CHRIS NOTH » Thu Dec 16, 2010 10:05 am
HI MY NAME IS CHRIS I LIVE IN AUSTRALIA AND HAVE A 2008 TURBO DEISLE CAB CHASSIS TRANSIT AT 120000 KM THE TIMMING CHAIN STRECHED THE FORD DEALER REPLACE IT ALONG WITH THE GUIDES AND TENTIONER AFTER ONLEY 12000K IT HAS DONE THE SAME THING THEY ARE BLAMING THE OIL BEING SLUDGEY IF THIS IS SO WHY SHOULD THIS STREACH THE CHAIN SO QUICKLY MY DRIVER SAID JUST BEFORE IT STARTED RATTLING THE ENGINE SEEMED TO LOCK UP AS SOME THING IN THE TOP END OR INJECTOR PUMP HAD MOMENTARELY SEIZED WHATS YOUR THOUGHTS ? THE DEALER DOESNT SEEM TO KNOW I DONT WANT TO SPEND ANOTHER
$2000.00 AUS WITH OUT FINDING OUT WHY IT HAS DONE IT IN THE FIRST PLACE PLEASE ADVISE REGARDS CHRIS NOTH
CHRIS NOTH
Re: TRANSIT TIMMIMNG CHAIN
Postby alexgrfc » Thu Dec 16, 2010 10:50 am
if you chain has stretched there a chance it may have jumped and your valve timing is possibly out ,the locking up will probably be the piston coming up and hitting a valve so there will be a good chance your valves could be bent :(
Transit t260 100
**********visit my blog @ http://www.transitpics.co.uk// **********
http://www.scottish-vanners.co.uk
alexgrfc
Postby b1jc » Mon Dec 20, 2010 12:43 am
Had this problem once.
Your CAPS is probably stuck on.
b1jc
Postby CHRIS NOTH » Mon Dec 20, 2010 7:30 am
HI GUYS FOUND THE PROBLEM WHEN SOME ONE CHANGES A CHAIN THEY SHOULD LOOK AT THE SPROCKETS AND THE ONE THE MOST LIKLEY TO CAUSE A PROBLEM IS THE DIESLE PUMP SPROCKET IT SEEM BECAUSE OF THE HIGH PRESURE THAT THE PUMP RUNS AT IT WEARS THE TEETH NEARLY TO A POINT THIS CAUSES THE CAHIN TO RUN ON THE TEETH EDGE THE REST OF THE GEARS IE CAM AND CRANK APPEAR OK BUT THE DIESLE PUMP SPROCKET IS WORN IF THIS IS NOT REPLACED IT WILL DESTROY A CHAIN WITH IN 10,000 KM SO HAVE A GOOD LOOK AT THIS AREA I HOPE THIS HELPS SOME ONE ELSE OUT REGARDS CHRIS PS( SOME TIMES IT PAYS TO LOOK AT THE REASON WHY SOMETHING FAILS) AND DONT RELY ON SOME ONE ELSES LAZY THOUGHTS
CHRIS NOTH
