cambelt question
cambelt question
Postby crayon » Thu Dec 16, 2010 1:17 pm
Hi guys i know this sounds silly but is the timing belt supposed tight or lose?
I belt snapped about 4 months ago, i replaced it using a guide from here, now the engine runs ok, it rocks a bit on idel but runs fine, but when the engine is off i can move the belt abou 3-4 inches? the tensianor is all the way does this sound right?
crayon
Re: cambelt question
Postby MinorMatt » Thu Dec 16, 2010 6:10 pm
sounds a bit loose mate :o I would suggest you shouldnt be able to turn it much more than 90 degrees...
Postby bazw » Thu Dec 16, 2010 9:15 pm
when you say "the tensioner is all the way " is this to the right or to the left ?
im guessing to the left if its a DI
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby crayon » Thu Dec 16, 2010 9:48 pm
Its all the way to the right
crayon
Postby jay » Thu Dec 16, 2010 10:03 pm
all the way to the right should be tight..did you get the right belt?
mk1 connect tourneo
jay
Postby bazw » Thu Dec 16, 2010 10:09 pm
could be threaded round the pulleys wrong but cant think of how it would run if it was
i know it took me a few goes to get it right the first time i did one
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby crayon » Thu Dec 16, 2010 11:04 pm
jay wrote:all the way to the right should be tight..did you get the right belt?
No idea just give my reg to the motor factors
crayon
