ive lost my only key...
Postby stevo1975 » Wed Dec 22, 2010 7:43 pm
Hi all, i was hoping someone would be able too give me some advise on removing one of the locks on my doors...
im trying to remove my passenger doorlock as ive been told by my local keycutter that he can make a new key by seeing an original cylinder.
Ive removed the door card and the rod that comes from the handle and the square washer type thing that holds the cylinder in place but cant seem to slide the actuall cylinder out... is there a knack to it or do i need to free some type of hidden pin or something or worse do i need the key to remove it???
Its a 2000 (Y REG) lwb 350 bonus...
many thanks stevo...
stevo1975
Re: ive lost my only key...
Postby robbie.cee » Wed Dec 22, 2010 8:17 pm
you have to take out window and regulator, drill out 4 rivets holding lock shield in place
use knife to cut glue holding plate to door
remove panel
take out screw for window rear channel to door pull channel down to release top clip
3 screws hold lock to door
slightly withdraw lock for access
release retainer clip
disconnect rod from lock barrel
if central locking, remove switch from barrel
remove lock retaining clip
lever out lock
refitting reverse order
from HAYNES MANUAL!
rob :D
merry chrimbo
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed Dec 22, 2010 8:21 pm
that for a mk5 or mk6 rob? Certainly sounds like mk5 to me when his is Mk6...
Stevo - the locksmith will be able to cut you a key that will open the doors but wont be able to programme a key in to start the van without plugging in to it!
Postby robbie.cee » Wed Dec 22, 2010 8:46 pm
yup mk5 sorry durrrrrr :lol:
Had
MAKE IT FIT
robbie.cee
Postby stevo1975 » Wed Dec 22, 2010 8:51 pm
MinorMatt wrote:that for a mk5 or mk6 rob? Certainly sounds like mk5 to me when his is Mk6...
thanks for replying amigo... im just desperate to get the cylinder to the keycutter so i can get a non chipped key to release the steering lock thus being able to tow it to ford so they can rape me with their £96 per hour labour costs...
if i cant get the cylinder out im looking at even more money to get the bugger transported to the dealer...
life is good...
stevo1975
Postby Backbone of Britain » Wed Dec 22, 2010 9:01 pm
Ring an auto locksmith he will come to you, cut you a set of keys and programme them all cheaper than ford and you wont have to leave the house.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby stevo1975 » Wed Dec 22, 2010 9:38 pm
i thought that would be even more expensive than the dreaded dealer what with callout charges ect...
ill phone one in the morning and see what the damage is... thanks for your imput gentlemen merry xmas...
stevo1975
Postby Backbone of Britain » Wed Dec 22, 2010 9:56 pm
stevo1975 wrote:i thought that would be even more expensive than the dreaded dealer what with callout charges ect...
There shouldn't be a call out charge unless he can't sort the problem, that's how they work around my way anyway.
One hours labour and the price for materials (keys and cutting) is all he should charge you.
Backbone of Britain
Postby MARKOVERTON » Sat Jan 01, 2011 12:24 pm
The front door locks on the MK6 are removed similarly to an ignition barrel, there is a tab which needs to be pressed in while the key is turned to remove it. You should see a very small hole in the door latch casing which you can poke a 2mm drill (approx) through it. Once the tab has been depressed the key is then turned the other way which turns the lock barrel slightly and the lock can then be withdrawn from the door.
I am not sure if you will be able to do this without causing any damage if you do not have the key.
MARKOVERTON
Postby Ollie » Sat Jan 01, 2011 3:18 pm
If the vans standard as it left factory go into dealer with the log boook and some id and they should be able to pull up the details from the factory, alltough in long run the mobile lock guys will be the easiest and prob cheapest anyway.
Ollie
Ollie
Postby Mikeeshaq » Mon Jan 03, 2011 2:11 am
In the USA
The manager of the Ford Dealer parts department can query the Ford system to get the key code
IF they can cut the keys, then maybe that will the simplest way to do it
In the USA, one has to prove ownership usually the insurance card will do before any keys are ordered/cut
Mikeeshaq
Postby robbie.cee » Mon Jan 03, 2011 7:43 pm
Mikeeshaq wrote:In the USA
hasnt anyone on here tried plugging pats sensor into a pc and getting creative yet??? :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Mon Jan 03, 2011 7:46 pm
life is good...
:D
Surely theres another forum member local to you that'll tow you if needs be? :?:
Had
MAKE IT FIT
robbie.cee
