seal dimension?
seal dimension?
Postby draganp » Thu Dec 23, 2010 10:56 am
ford transit 2009, 2,4tdci, 74kw, twin wheel, rwd
i need more information about bearinb and seal on rear wheel.
does anybody know the dimensions of that seal or oe/ford number?
regards
draganp
Re: seal dimension?
Postby AndyG » Sun Dec 26, 2010 1:42 am
You'll need to double check, but from what I can gather (not knowing exactly what variant) the seal number is FINIS code 1521590 @ about £22 + 20%
The bearing is available as a kit, (again, double check) FINIS Code 4479002 @ about £156 + 20%
If you're pulling this apart, you may also need the gasket kit and the retainer-bearing too :|
