Suspension problem....
Postby paulcbr » Sat Jan 01, 2011 3:55 pm
First off happy new year to y'all. :)
Now my van is a Y reg 2.5 turbo smiley face ex ambulance.
I've had it 2 years and the ride was smooth to begin with(as you'd expect from an ambulance) but has gradually got harsher and now picks up every bump in the road with a bang, making for an unpleasant ride.
It was moted a month ago and they could find no problem.
So, any ideas folks? Can springs or dampers go "hard" with time?
Thanks in advance.
paulcbr
Re: Suspension problem....
Postby Altransit » Sat Jan 01, 2011 4:39 pm
I would start by checking the rubber bushes in the shock absorbers :D
Postby AndyG » Sat Jan 01, 2011 4:45 pm
Does it have air suspension :?:
Have you been removing the "load" :?:
Can you not tell if the problem is with one particular corner, front or back suspension :?:
Postby paulcbr » Sat Jan 01, 2011 4:58 pm
Rubber bushes each end of the shocks are good.
The problem seems to be front both sides, no air suspension Andy.
I'm doing a camper conversion on it, so with the kitchenm wet room etc I would say it's carrying around the same weight as when it was kitted as an ambulance.
paulcbr
Postby Ollie » Sat Jan 01, 2011 5:02 pm
Is it on leaf springs? have they rusted up through lack of use? try excercising it a bit fully loaded!
Ollie
Postby paulcbr » Sat Jan 01, 2011 5:06 pm
Although I'm converting it is still used daily so not lack of use.
It has coil springs and shocks front, leaf springs and shocks rear.
paulcbr
Postby ericspets » Sat Jan 01, 2011 5:48 pm
I've just got a similar problem. mk6 T260.
Just went over a speed bump (not fast by the way) and there was an almighty bang from the front nearside, and then a smaller bang every little hole.
I can't see anything that is obviously broke so i drove steady home, only about a mile. When i got home i've noticed that the clearance above the wheel to the wheelarch is only about half of the drivers side.
I'm leaving it till tomorrow now, but will be suspecting a broken spring.
On my old Sreg tranny i had about 6 front springs in 8 years due to the road humps and i consider myself to be quite careful. I do do a lot of local delivery milage over the bloody things though.
ericspets
Postby paulcbr » Sat Jan 01, 2011 9:33 pm
Thanks for the replies so far folks.
I've had another look at it, no broken springs, but I did notice "rub" marks where the first and second bottom coils (on both front springs) have been making contact with each other.
Is this normal?
paulcbr
Postby MinorMatt » Sat Jan 01, 2011 11:50 pm
Given its an amby I would expect to see anti roll bars front and back... If the springs arnt broken I would be having a good look at them and the bushes
