Rear drum query on mk2.
Postby whitemice » Thu Jan 06, 2011 3:24 pm
Got a pair of new drums for a tenner! I reckon one was drilled on friday night as it's a little out as picture, central but not square on raised stud locations, i reckon it will be ok safetywise on my 1985 mk2 ambulance, do you? :mrgreen:
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Re: Rear drum query on mk2.
Postby jay » Thu Jan 06, 2011 9:31 pm
wonder if the little screw will line up once the drum is over the wheel studs..
mk1 connect tourneo
jay
Postby whitemice » Fri Jan 07, 2011 10:34 am
jay wrote:wonder if the little screw will line up once the drum is over the wheel studs..
That is 'radially offset correctly' :mrgreen: too Jay, it lines up fine.
Like i say the main thing is whether there are any safety issues in using this particular drum, my opinion is it's ok but i would like more widely learned peoples views/experience.
whitemice
Postby Altransit » Fri Jan 07, 2011 10:37 am
Unless the wheel doesn't seat correctly in those recesses, it should be fine :)
Postby whitemice » Fri Jan 07, 2011 10:42 am
Altransit wrote:Unless the wheel doesn't seat correctly in those recesses, it should be fine :)
Thanks for your view AT, on the lwb amby once the drum is on the stud's the split washers are fitted and the twin wheels go on them followed by the nut's.
whitemice
Postby whitemice » Sun Jan 09, 2011 2:11 pm
As i asked during the week i thought i would bump the thread as folk are more likely to be online, question really is whether this particular drum is safe to use? As you can see Jay and myself feel it will be fine, but does anyone know better?
whitemice
Postby Luke » Sun Jan 09, 2011 2:17 pm
if your on about the drilled holes not being in the centre of the spotface then providing whatever mates to that face doesnt fould the rough casting then yes perfectly safe to use :D
Postby whitemice » Sun Jan 09, 2011 2:31 pm
Luke wrote:if your on about the drilled holes not being in the centre of the spotface then providing whatever mates to that face doesnt fould the rough casting then yes perfectly safe to use :D
Thanks Luke, yes nothing would foul the casing as the wheels get seated on the split washers, the drillings are only out by no more than @3mm and there is still plenty of thicker shoulder metal, I would really like to fit them as there has been a very slight oscillation apparent on the pedal over the last year which i put down to very slight ovality in the old drums which are 26 years of age now, at the price i got them for of £5 a drum it is a no-brainer not to fit them with the new springs/ratchets/handbrake cable and fairly recent shoes/pistons. They are good quality drums and made by Delphi. Only thing is i'll have to re-paint the wheels now with white poly to match the bling of everything else!
whitemice
