Hi all hope you can help
2004 135 tdci tranny with a fault code P0200 injector circuit fault
pulled the injector plugs and tested voltage cylinder 1 was giving out 5.4v with ignition on cylinder 2 was only giving out 1.7v and cylinder 3 and 4 was 5.4v, checked the wiring harness back to the main plug and had continuity from the injector plug to the main plug on both cables so put it down to a faulty injector got hold of a new 1 today and fitted but still got the same problem anyone able to help
cheers paul
