Rod Smith wrote:Well I got the pipe off,but only after dropping the subframe and the rear gearbox mounting!
I pulled the box out and the clutch was shot as was the DMF,after a bit of phoning round it appears no one makes a solid flywheel conversion for this model [6 speed TDCi] so had to go Ford ££££££'s
Blanking the EGR pipe is an option,easy enough on a banana engine but a bit of a pig on this one,I;m fitting a new pipe anyway,but think I might blank it off at the EGR end to see what happens,judging by the amount of crud in the manifold etc dont think it can hurt.
there is a solid conversion for this van 135 tdci one of the ebay transit centres do them they are a made up by them self using o.e luk which is the o.e and im told they are as good as the other kits for the smaller ps,
these vans are sold in other countries from new with a solid kit fitted as standard,its just that we are told by the manufacturere we need a bit more refinement (they think we have more money than our european cousins to pay for the soddin things)
