whining axle!
whining axle!
Postby trantastic » Fri Jun 03, 2005 8:31 am
have just purchased 1968 mark 1 campervan and has whining rear axle over 40 miles an hour. seller has sourced a replacement does it need changing or can it be silenced any other way :roll:
stress is the mind overriding the bodys' desire to choke the living s**t out of somebody who truly deserves it!!!!
trantastic
Postby FredTransit » Fri Jun 03, 2005 8:59 am
Best Replace it mate, anything you do to shut up the diff will only be temperory, and you will end up with it off the road in the end. On the other hand, you will be suprised how long these things will whine on, sometimes for years! Have you checked the oil? Has it got any?
FredTransit
Mk2 Trannyist
Postby madmark » Fri Jun 03, 2005 10:39 am
if you have the chance to change it then would be a good idea ,unless you dont mind the noise,as fred says it will go on and on! :D
mk2 diff noise
Postby simon » Sun Jun 05, 2005 3:24 pm
I just got hold of a mk2 with a 3l essex in it.The diff howles like an owl over 40 mph but stops when i ease off the gas.I tried to check the oil but theres no filler or drain holes on the diff.Does it need a replacement diff or can the slack be taken up,or does it just need oil.
simon
Re: mk2 diff noise
Postby Luke » Sun Jun 05, 2005 7:38 pm
simon wrote:theres no filler or drain holes on the diff.
are you sure? the filler plug should be at the front next to the propshaft flange!!
:D
Re: mk2 diff noise
Postby FredTransit » Sun Jun 05, 2005 9:57 pm
simon wrote:I just got hold of a mk2 with a 3l essex in it.The diff howles like an owl over 40 mph but stops when i ease off the gas.I tried to check the oil but theres no filler or drain holes on the diff.Does it need a replacement diff or can the slack be taken up,or does it just need oil.
Like Luke said, are you sure, these are not sealed units, and do need to have the oil checked and topped up from time to time, so have a good look, there must be one.
FredTransit
Mk2 Trannyist
diff
Postby Jim H » Tue Jun 07, 2005 3:30 pm
My square axle diff on my 98 swb started to wyne in March and this morning i turned around cos the noise is now that bad,so don't leave it to long!
Jim H
Postby madmark » Tue Jun 07, 2005 3:57 pm
the rear axles are not sealed units! :D you will find the plug on the side of the diff caseing! on the nearside! :)
Diff Oil
Postby chrisvmax » Fri Jun 10, 2005 3:17 pm
Does it matter what oil is used in a Mk2 twin wheel diff?
I'll try to get a picture of my ambulance on here soon. New bonnet should be going on this weekend!!
Regards,
Chris
chrisvmax
