manifold question
manifold question
Postby simgy » Tue Jun 14, 2005 12:20 pm
hi all when fitting a mk3 pinto into my mk2 i used my old manifold as the mk3 is a bit to big to fit the downpipe onto.on returning from the first test run (2 mile) the manifold was starting to glow red hot.now the engine was buggered (knocking cam) and having now fitted a different engine am wondering if i should use the mk3 manifold and get a mkk 3 downpipe,or was the knackered engine making it overheat? can u use a mk2 manifold and exhaust on a mk3 engine?
simgy
Postby Luke » Tue Jun 14, 2005 12:28 pm
:shock: thats a strange one!!
i cant see any reason the mk2 manifold caused the problem - i'd assume the knackered engine was at fault!!
Postby simgy » Tue Jun 14, 2005 12:49 pm
thanks luke just wondering as the old one is square and the other round as you know looks like ill have to change it again and see what happens :?
simgy
Postby Luke » Tue Jun 14, 2005 1:02 pm
Mate you might be better with the mk3 - it might be a more efficiant design :idea: mabe someone on here knows :?:
Postby simgy » Tue Jun 14, 2005 1:30 pm
luke you might be right it certainly looks more efficient.also the flange is slightly bigger and the downpipe is a different shape so just hope its all gonna fit :!:
simgy
Postby madmark » Tue Jun 14, 2005 2:06 pm
if you can use the mk3 type then its a bonus but mk2 wouldnt make any difrence ,a manifold would not cause the engine to go wrong! :D
Postby simgy » Tue Jun 14, 2005 2:13 pm
engine was already shafted when i got it mark just wondered if the manifold was glowing red due to over restricting the exhaust gases or if the knackered engine was doing it
simgy
Postby madmark » Tue Jun 14, 2005 2:39 pm
no mate that wouldnt cause it to do that, when you put another engine in it should be ok! :D
Postby FredTransit » Tue Jun 14, 2005 3:05 pm
You have to use the Mk3 manifold and downpipe if you are fitting an MT75 5 speed, so it won't make any difference to the engine. The manifold and downpipe off the Mk2 4 speed doesn't get round the bigger 5 speed box.
FredTransit
Mk2 Trannyist
Postby simgy » Tue Jun 14, 2005 3:50 pm
thanks mark. fred,does the mk3 downpipe match up to the mk2 middle section ok :?:
simgy
Postby FredTransit » Tue Jun 14, 2005 4:28 pm
simgy wrote:thanks mark. fred,does the mk3 downpipe match up to the mk2 middle section ok :?:
I think so, but no too sure as it's a long time since we did a gearbox swap. To be honest we usually swap the whole exaust and save any good bits for the others.
FredTransit
Mk2 Trannyist
