Diesel/Petrol speedo
Postby chrisvmax » Wed Jun 15, 2005 4:54 pm
Hi,
In my MK2 LWB twin wheel ambulance I have a 2.5 di engine / gearbox fitted. There would originally have been a petrol engine of some sort in there.
Because the gearbox is changed I think my speedo is probably inaccurate.
Is it?
Can it be sorted?
Regards,
Chris
chrisvmax
Postby madmark » Wed Jun 15, 2005 5:25 pm
hi mate it could be sorted , but getting the corect speedo drives for the gearbox is very hard now, you will have a 4.63 rear axle if the van was original a front line amby it would of had a 3ltr v6 engine , depending what van you got the gearbox from the speedo would most likely be out! normaly the best way to check this is do you know anybody with a road angel speed camara detector , if you do you could borrow it and plug it in and see what speed you are dooing to the road angel ,these are acurate as they run on gps, this is what i done with mine then marked the speedo with white paint to were my 30-40-50-60 mph is ! hope this helps .mark
Postby FredTransit » Thu Jun 16, 2005 9:25 am
madmark wrote:hi mate it could be sorted , but getting the corect speedo drives for the gearbox is very hard now, you will have a 4.63 rear axle if the van was original a front line amby it would of had a 3ltr v6 engine , depending what van you got the gearbox from the speedo would most likely be out! normaly the best way to check this is do you know anybody with a road angel speed camara detector , if you do you could borrow it and plug it in and see what speed you are dooing to the road angel ,these are acurate as they run on gps, this is what i done with mine then marked the speedo with white paint to were my 30-40-50-60 mph is ! hope this helps .mark
.........or blue tac a calculator to the dash, or use hands free and phone a fried with a calculator!! Or guess and get used to it!
FredTransit
Mk2 Trannyist
Keep guessing....
Postby chrisvmax » Thu Jun 16, 2005 12:35 pm
I've been doing the guessing game so far. If I could get a speedo from a petrol Mk2 would it correct the reading?
For now I'll keep guessing. It's soooo slow the chances of a speeding ticket are pretty slim :lol:
Top speed 65mph!! :roll:
Regards,
Chris
chrisvmax
Re: Keep guessing....
Postby FredTransit » Thu Jun 16, 2005 12:44 pm
chrisvmax wrote:I've been doing the guessing game so far. If I could get a speedo from a petrol Mk2 would it correct the reading?
Regards,
Chris
The speedos thenselves are the same for whatever model, it's the speedo gearing in the gearbox you need to change, and they are not easy to come by. As for the top speed, that's still possible to get you a ticket doing 50 in a 40 area. Just judge it by the other traffic.
FredTransit
Mk2 Trannyist
Postby bortaf » Fri Jun 17, 2005 12:16 am
Tipex my man :lol:
when i put another MT in me LWB out of a SWB the speedo was well over reading so i got the wife to drive in front of me in a car that hadn't been played with (the only one i have access to out of 6 :lol: ) she flashed the hazards every 10 MPH and i marked the dash and it's still there :oops:
in 3 vans, one cortina and me recovery only the escort reads properly :lol:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby FredTransit » Fri Jun 17, 2005 8:33 am
bortaf wrote:Tipex my man :lol:
I like it! If I were you bortaf, I would submit this one to technical how to! :lol:
FredTransit
Mk2 Trannyist
Postby Boner » Fri Jun 17, 2005 8:53 pm
Here are my 2 methods.. 2 vans both accurate as far as i know. one van faster though so its the 2nd table.
1st gear=10
2nd gear=20
3rd gear=30
4th gear =40
5th gear =50 :lol:
I use this van for work so its gently driven most times.
or
1st gear =20 with lots of wheelspin
2nd gear= 35 slam it into second
3rd gear = 60 if u want to really get moving. and they all do in this gear :roll:
4th gear = kin as much as the engine ge ya capatin otherwise pointless.
5th gear= ur deffiantly breaking a speed limit of sorts surly and vibrations are terrifying,brakes almost no use stopping from these speeds :lol: doom crash burn agghhhhh.
I think bouncy speedos are the funiiest to judge.. my m8s transit is roughly 10mph to fast when ur hammering it but is ok when ur gentle lol lol i have found a 285 mile trip on a motorway at steady speeds solves this problem/
Totaly irrelivant but i no been booked yit.. Good luck m8.
Boner
I willingly drive a white van for a living, not through choice more for comfort!
Boner
