2002 VH 2.4 ASM tddi locked in gear
Postby frankv10 » Tue Sep 13, 2011 10:19 am
Hi hope someone can help my 2002 VH transit 2.4 duratorq Diesel with automated gear shift has locked it self in 1st gear and will not start we have checked everything fuses Etc.and can not see anything wrong is it possible to manualy put it in nuetral ???and maybe start her up
any help will be great
Frank
frankv10
Re: 2002 VH 2.4 duratorq tddi locked in gear
Postby taz666 » Tue Sep 13, 2011 5:50 pm
the only way to get this sorted is to get codes read, the system has identified a fault and shut down, the asm system is an absolute nightmare and sometimes really difficult to diagnose
taz666
Ford Technician
Postby frankv10 » Wed Sep 14, 2011 12:57 am
thanks for that I should have mentioned the van has been in the workshop for some time at first the injector pump was replaced and caused problems and now it was running fine when it was taken for a test run but when they tried to restart it came up with the gear change locked in 1st, they have tried a new module but still doing the same thing .
Frank
frankv10
Postby AndyG » Wed Sep 14, 2011 1:14 am
I read somewhere on here that there's a grey relay that can give trouble, so check your relays out :idea:
1st gear is automatically engaged on switch off AFAIK :!: So it may be just a lack of voltage (blown fuse)
Good luck :!:
Postby frankv10 » Wed Sep 14, 2011 5:17 am
thanks for that I will check relays again ,but I think it use to go in heutrel when you shut down as it wont start in gear just like a auto
Frank
frankv10
Postby AndyG » Wed Sep 14, 2011 3:07 pm
That's right, it goes to neutral when you switch ign. on and you should hear the ASM pump running :idea:
Foot needs to be on the brake pedal, so also check the brake lights and switch/es are working correctly in that area :idea:
Postby frankv10 » Thu Sep 15, 2011 11:07 am
you are the greatest, faulty reley replaced and she is off and running
thank you so much I'm so glad you guys are here to chat with
thanks you very much
Regards Frank
frankv10
Postby AndyG » Thu Sep 15, 2011 11:30 am
And thank you frankv10 for posting back, confirming it was just a simple relay fault :D
Can you take a picture of the position of this faulty relay :?:
Postby frankv10 » Fri Sep 16, 2011 8:09 am
Its a bit hard to take a photo of becouse its under the main fuse box under the bonnet. a realy easy spot to get to NOT.
and you where right there is 1 grey and 1 black relay both have been replaced but the grey one was all rusty inside
I will try and take a photo on the week end and post it on here
Frank
frankv10
Re: 2002 VH 2.4 ASM tddi locked in gear
Postby AndyG » Fri Sep 16, 2011 10:26 am
Many thanks for posting the position of the relay, even if we don't get any photos, at least we now know where to actually look :D
