I have some parts which someone can have if you can identify them from these pictures.
There are four of each of these bushes.
Some bearings. Don't know what for. 1 is a ford part the other two are not
King pin set? It says it on the box but it might not be the right box
Loads of different washers, all with different Ford part numbers
That's it then. If you know what these parts are and you want them then let me know. Some of the bits are quite heavy though so if you want them posting it'll cost you a few quid.
