****NOW BOOKED FOR 2022**** Transitmania 13 @Santa Pod 20th 22nd May 2022 ****ALL DETAILS HERE****
mk5 4x4 IFS bits
Advertise any transit parts you have here free to other members!!
mk5 4x4 IFS bits
Postby billyboy » Sat Oct 02, 2021 1:48 pm
Mk5 COUNTY 4X4 IFS bits
Garage clearance free to good home
NEW:- bottom swivel
CV joint, + rubber boots
USED:-
2-bottom arms+tie rods
2-front brake discs+hubs
2-front callipers+carriers
4-front shockers
3-front road springs
1-rear hub (fully floating)
Standard Mk5 LWB bits
Set of 4 steel wheels(6 pin) with part worn Kumho road adventure MT 235/75xR15
1-steel wheel (6 pin)with BF Goodrich AT 235/75x15
2/door cards
2/Head lights (plastic)
N/S elec window winder
Steering wheel(air bag type) no air bag + control unit
2/f/n/s outer wheel arch
Rear x member(2 pieces)
f/spring hanger
3/outer sill panels
1/outer sill(below sliding door)
Instrument cluster
Sliding door bottom track and brackets rollers
Box of seat belt odds and sods.
billyboy
Re: mk5 4x4 IFS bits
Postby MinorMatt » Mon Oct 04, 2021 4:29 pm
I wouldn't mind them if thats OK Billy? I'm doing a parts run on Sunday - so could add it to that?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby billyboy » Mon Oct 04, 2021 6:21 pm
MinorMatt wrote:I wouldn't mind them if thats OK Billy? I'm doing a parts run on Sunday - so could add it to that?
Hi Matt, are you having everything? 'cos I had better get everything ready for you. They are all over the place.
Bill
billyboy
Postby MinorMatt » Tue Oct 05, 2021 8:30 am
Whatever you don't want Billy :)
93 L GL Minibus
Postby billyboy » Tue Oct 05, 2021 11:15 am
MinorMatt wrote:Whatever you don't want Billy :)
Ok Matt, well you are the only taker, it's just that I will have to raid the loft, shed, to say nothing of the garage for Sunday. It's all been kept indoors.
Any idea what time on Sunday? .... Bill
billyboy
Re: mk5 4x4 IFS bits ALL GONE NOW
Postby billyboy » Sat Oct 09, 2021 11:41 am
billyboy wrote:Mk5 COUNTY 4X4 IFS bits
NEW:- bottom swivel
USED:-
4-front shockers
2/door cards
f/spring hanger
3/outer sill panels
Instrument cluster
billyboy
Return to Free to good home!!
