mk5 4x4 IFS bits
Mk5 COUNTY 4X4 IFS bits
Garage clearance free to good home
NEW:- bottom swivel
CV joint, + rubber boots
USED:-
2-bottom arms+tie rods
2-front brake discs+hubs
2-front callipers+carriers
4-front shockers
3-front road springs
1-rear hub (fully floating)
Standard Mk5 LWB bits
Set of 4 steel wheels(6 pin) with part worn Kumho road adventure MT 235/75xR15
1-steel wheel (6 pin)with BF Goodrich AT 235/75x15
2/door cards
2/Head lights (plastic)
N/S elec window winder
Steering wheel(air bag type) no air bag + control unit
2/f/n/s outer wheel arch
Rear x member(2 pieces)
f/spring hanger
3/outer sill panels
1/outer sill(below sliding door)
Instrument cluster
Sliding door bottom track and brackets rollers
Box of seat belt odds and sods.
NEW:- bottom swivel
USED:-
4-front shockers
2/door cards
f/spring hanger
3/outer sill panels
Instrument cluster
