I have removed a 2.4 York from my 3 ton Unimog - I need more power. The engine looks crusty but always starts in a couple of revs if you heat for 20 secs. The rocker cover has a sticker saying Ford Recon unit. I put a new cam belt and water pump on 500 miles ago.
The engine has a modified sump and the vac pump hole is blanked off.
I dont want any time wasters or dreamers - it is in a field near Dursley Gloucestershire and I can help to load most Saturdays - otherwise the scrap yard is 1/2 a mile away.
It is free - any takers?
