hi all, i have a swb smiley transit, tax out and just a little left on mot. i put too much oil in it and it started spewing black smoke. but before that it was going fine apart from losing a bit of power when going along, sort of hitting a deadspot then adjusting back to normal, i see on here its a common problem. anyway van is yours if you want it. all cills welded by doors recently done, new cat converter with the gizmo on it that monitors oil/petrol ratio, forgot what its called. newish exhaust.
usual rust on wheel arches that i reformed and rubbed down, havent painted, 5 good tyres. someone tried to nick it last night (hotwire) so its a tow job. new towbar. its in brighton if you want it. call 07926803818, alan forgot to say all new springs and ball joints 6 months ago and brakes
