derv23 wrote:Cracking work , as always![]()
At the rear of the panel where it meets the rear pillar , will that be welded up the seam , or spot welded then filled ?
If you fit the inner panel first then you cant get to the flange (below the swage at floor level) so you just weld it from the outside (its hidden behind bumper end cap anyway so just dress any welds and apply sealer) the top half can be spot/plug welded from inside the van
The front end is a bit more fiddly (if you want to keep the seam (below floor level) looking original, I've never tried it but it "might" be easier to test fit everthing then actually weld the outer panel in first which would give you access to the full length of the flange inside, then fit the inner arch and weld it in
