Made up 2 pieces of ply to seal in most of the side of the fridge enclosure. The plan is to screw them in, then aluminium foil tape to seal the gaps. Mainly to stop draughts ...
Also, the gas vent hole has been attended to. That hole is 40mm wide, which is more than sufficient for the drain. It's black, because I masked it all off then gave it a shot of Smoothrite down there to paint the metal I'd cut ...
Not shown in pictures:
- Internal bracing in the furniture, which was falling to bits.
- Cut a hole to allow the sink hose to get to the waste water outlet.
- 30 mile round trip to get the 80p part to connect the sink to the outlet
