Ah I see so 2k & 1k are no compatible then, I mean the ratio of lacquer and thinners isn’t it 1 - 1.
Are you going to flat the primer down before paint, remember this is the most important stage.
Looking good so far
ned wrote:Ah I see so 2k & 1k are no compatible then, I mean the ratio of lacquer and thinners isn’t it 1 - 1.
Looking good so far
ned wrote:Did you get the paint local? I’d be going back with the lacquer as it seems faulty if it ready to shoot and comes out like that.
When I painted the Alfa the one thing I wish I had done was to go around it with a torch and check for small dents there are one or two that stand out and really piss me off.
Going to look good once it’s finished.
You’ve used that 4 way stretch van lining in the past haven’t you? Is it easy to work with
loot wrote:ned wrote:Did you get the paint local? I’d be going back with the lacquer as it seems faulty if it ready to shoot and comes out like that.
Stretch carpet is great, can of spray glue apply to both pieces to be joined then work it along.
That's on my list of to do.
I have the full tourneo interior trim. I'm deffo going to carpet the front and rear roof linings. I don't know whether to line the plastics or throw them and carpet the van body direct
ned wrote:Aye I had the headliner out while fitting the new horns and tidying some wiring up, much easier, it is addictive, thinking what else I can carpet![]()
Good idea painting the inside, door jambs ect before the outside, watch your timing between coats and the weather you don’t want the paint to flash too quickly or it’ll look poop, is the mix 2 parts paint, 1 part thinners and 1 part activator, when I did the Alfa I mixed up about 2L ready so I could just shoot it without having to mix more, should be looking shape once it’s painted and polished
